Hi all!
I'm trying to learn about python and deep learning. I have tried to follow the sample notebooks and watch the training courses but now i'm stucked.
I have done some training samples in Arcgis Pro with the training samples manager and saved it as a shapefile.
Then i export the samples with GP-tool "Export Training Data For Deep Learning" with KITTI Labels as Meta Data Format.
In jupyter notebook i write this to load the samples
from arcgis.learn import prepare_data
data = prepare_data('Path to my samples')
data.show_batch
The error i get
~\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone4\lib\site-packages\arcgis\learn\_data.py in prepare_data(path, class_mapping, chip_size, val_split_pct, batch_size, transforms, collate_fn, seed, dataset_type, resize_to, **kwargs)
572 return ner_prepare_data(dataset_type=dataset_type, path=path, class_mapping=class_mapping, val_split_pct=val_split_pct)
573 else:
--> 574 raise NotImplementedError('Unknown dataset_type="{}".'.format(dataset_type))
575
576 if dataset_type == 'RCNN_Masks':
NotImplementedError: Unknown dataset_type="KITTI_rectangles".
What am i doing wrong?
Regards Mattias
