I'm trying to login in ArcGIS Enterprise, using a fairly standard call:
gis = GIS(portalUrl, user, pass)
This used to work, but now I get an error:
2023-03-07 10:08:59,110 - DEBUG - Connecting to portal: example.com
2023-03-07 10:08:59,114 - DEBUG - Starting new HTTPS connection (1): example.com:443
2023-03-07 10:09:00,029 - DEBUG - https://example.com:443 "GET /portal/info?f=json HTTP/1.1" 500 7058
2023-03-07 10:09:00,035 - DEBUG - https://example.com:443 "GET /portal/rest/info?f=json HTTP/1.1" 500 7058
2023-03-07 10:09:00,042 - DEBUG - https://example.com:443 "GET /portal/sharing/rest/info?f=json HTTP/1.1" 200 139
2023-03-07 10:09:00,048 - DEBUG - https://example.com:443 "GET /portal/rest/services?f=json HTTP/1.1" 500 7058
2023-03-07 10:09:00,157 - ERROR - Please ensure gssapi is installed
2023-03-07 10:09:00,171 - DEBUG - Traceback (most recent call last):
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\auth\_auth\_winauth.py", line 75, in __init__
creds = gssapi.raw.acquire_cred_with_password(
File "gssapi\raw\ext_password.pyx", line 75, in gssapi.raw.ext_password.acquire_cred_with_password
gssapi.raw.exceptions.BadNameError: Major (131072): An invalid name was supplied, Minor (2529639136): Configuration file does not specify default realm
During handling of the above exception, another exception occurred: Traceback (most recent call last):
File "D:\Data\MOR\Migratie\Download-wf5.py", line 45, in <module>
main()
File "D:\Data\MOR\Migratie\Download-wf5.py", line 33, in main
gis = GIS(settings.ARCGIS_PORTAL_URL, settings.ARCGIS_USER, settings.ARCGIS_PASS)
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 585, in __init__
raise e
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 524, in __init__
self._portal = _portalpy.Portal(
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 205, in __init__
self.con = Connection(
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 344, in __init__
self._create_session()
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 691, in _create_session
self._session.auth = EsriWindowsAuth(
File "D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\auth\_auth\_winauth.py", line 84, in __init__
raise Exception("Please ensure gssapi is installed")
Exception: Please ensure gssapi is installed
A few things to notice:
- Some requests to the portal return HTTP 500
- The first error is Configuration file does not specify default realm . Which configuration file could this be referring to?
- The second error is Please ensure gssapi is installed
This is on a client's environment, so I'm not sure if anything relevant has changed recently. One thing that did change is an upgrade to ArcGIS Pro from 3.0 to 3.1.
