I'm trying to display a simple map control with one dynamic layer. I started with code similar to the simplest example here: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm. This code works on a sample silverlight application using silverlight API I made. The WPF application crashes with 401 error without details.
If I'm setting the Credentials property to a privileged user it runs but it displays a blank screen and in the eventviewer of the server I'm seeing few success audit messages and after them a few failure audit messages from Kerberos with that message: "unknown username or bad password" and no other details. My company's network is using Windows authentication.
I don't know about WPF API but in silverlight api, we've set up a proxy page and all the request to our services are directed to this proxy page for credentials. If its intranet application, then we use window authentication to access the service. If you want to know more about the proxy page set up let me know.
