Add an attachment image to popup infoWindow for ArcGIS API for silverlight
3830
11-03-2015 05:52 AM
soumahorosahi_ibrahim
Hello guys,
I'm suppose to show image photo on a click event(specific point) in a pop up infoWindow from a service
which has an attachements . The attachement has set of photos .
Best Regds,
Ibrahim Sahi
Developer intern at CNTIG
YueWu1
by Esri Regular Contributor
Hi Ibrahim,
This is a pretty good question. Based on my knowledge, in order to accomplish this task, you need to use AttachmentEditor​ & InfoWindow Class. You can take a deep look about that AttachmentEditor link and try to connect attachments by click features on map, and then you can try to merge this function within the info window.
You can based on this infoWindow sample to extend the attachmentEditor function to access the attachment to infoWindow popup.
Essentially, the logic is:
1. Get connect to attachment to feature services by using AttachmentEditor
2. Use infoWindow class to wire up the attachments
Hope this can help.
Best Regards,
Nathan
ReneRubalcava
This is a pretty old, but the basics are the same.
Add an attachment image to popup infoWindow for ArcGIS JavaScript API. · GitHub
When you have the graphic you can query the attachments from FeatureLayer and display images in the popup.
Asgharkhan
The best way for this i know for silverlight is use custom tool tip control template, then bind it with images.  The only problem is its work on hover not on click...
Thank you  guys for all your replies im gonna try all the methods and keep you update asap thanks !
