DataGrid not working well
3601
04-05-2015 04:25 AM
Asgharkhan
i reproduce attribute query with data grid , every thing is fine but now the problem is when i select the feature its give me invalid cast exception,
this code working well in another query.
  private void FindDetails_SelectionChanged(object sender, SelectionChangedEventArgs e)
            // Highlight the graphic feature associated with the selected row
            DataGrid dataGrid = sender as DataGrid;
            int selectedIndex = dataGrid.SelectedIndex;
            if (selectedIndex > -1)
                FindResult findResult = (FindResult)FindDetailsDataGrid.SelectedItem;
                Graphic graphic = findResult.Feature;
                 switch (graphic.Attributes["Shape"].ToString())
  case "Polygon":
                        graphic.Symbol = LayoutRoot.Resources["HighlightFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                    case "Polyline":
                        graphic.Symbol = LayoutRoot.Resources["HighlightLineSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                    case "Point":
                        graphic.Symbol = LayoutRoot.Resources["PointMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                        graphic.Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
nakulmanocha
Which line is throwing the error? Can you share some more code?
