Hi
I try to use FeatureDataForm to edit FeatureLayer.
Everything works fine (Geometry, string Fields, Data field edit and saved),
but if I edit an existing layer the data in floating point (type Double) - no data is saved.
As I understand, the problem is in the system regional settings - system decimal separator
ArcGIS 10, Silverlight API 2.2 (build 629), system decimal separator = ","
example:
72.1 => data is not saved and Commit button not enabled
72,1 => data is stored as 721
if I change the system decimal separator on "." all OK, but I can not change the settings for all clients
How do I save floating point data?
