I put a comment below, but basically when setting the Geometry of the identify just expand the extent of the point by however much you want. This example does 10%. private void QueryPoint_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e)
ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint;
ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
//Just get the extent and expand it, this one is expanded by 10%
Geometry = clickPoint.Extent.Expand(1.1),
MapExtent = MyMap.Extent,
Width = (int)MyMap.ActualWidth,
Height = (int)MyMap.ActualHeight,
LayerOption = LayerOption.visible,
SpatialReference = MyMap.SpatialReference
IdentifyTask identifyTask = new IdentifyTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/" +
"Demographics/ESRI_Census_USA/MapServer");
identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
identifyTask.Failed += IdentifyTask_Failed;
identifyTask.ExecuteAsync(identifyParams);
GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
graphicsLayer.ClearGraphics();
ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
Geometry = clickPoint,
Symbol = LayoutRoot.Resources["DefaultPictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
graphicsLayer.Graphics.Add(graphic);
