Labels
843
05-23-2011 07:34 AM
AndyBurnell
New Contributor III
Hi I was wondering if there is an easy way to add a button in the layer list to turn on/off labels? I have 11 layers in my map containing many entries. I would like the user to be able to control when the label is displayed.
Andy
JenniferNery
How are you adding labels on your layer?
AndyBurnell
New Contributor III
My labels are turned on through the layer properties in my MXD file. I know that I could create annotation layers but I wanted to keep the web map clean. I was just wondering if there was some control that I could add that would allow this.
JenniferNery
Our API does not support labelling and annotations. But you could use GraphicsLayer with MapPoints that use TextSymbol that binds to an attribute http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AddGraphicsXAML. If your layer contain polygon, you can use LabelAsync to get a good label position. http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#LabelPoints
AndyBurnell
New Contributor III
Thank you very much for the info and timely responses.
Andy
