My Silverlight (API 2.2 ArcGIS 10) application currently accessing the secured map services though the proxy url and it works fine. Next, I am performing ???Export Map??? (using REST API) on secured map services and I get ???Invalid token??? error, which is expected error (since no token has been used in my rest url). I can generate the token in the client side and pass the token to REST url to make it work, but I would like to avoid passing user name and password to client side (security) to generate the token.
My question is, how can I use proxy for the rest operations? If not is there any way to get (dynamic) token back from the proxy to the client side, so that it can be used for REST operations.
Any help on this is greatly appreciated.
Srv
