I spend few days in attempting to get silverlight app work with ArcGis Server 10 sp5.
The problem in that after compiling new silverlight project I got only blank screen if I use ArcGis Service. If I set up link to ESRI public service I see the map.
I tried to run demo JS app with same connection string to service, and it's work well.
I tied to do full reinstall of service, but there are now result. I can access to my service via rest protocol, and I see that it's work fine.
The problem is only that Sillverlight app do not show any layers. When I used 9.3.1 server all worked fine. And I did not changed nothing in Visual Studio settings. Only path to new service.
I tried to build app on server with silverlight viewer, and it's work fine, but it's failed when I try to compile it's as SL project.
Silverlight viewer is work fine for me! The problem is only with App done in VS2010.
Who can help me? I tried to googled, but I have found only few mention about this problem.
