Township Section and Range
2000
04-14-2010 01:52 PM
BrianGustafson
New Contributor III
Has anyone come up with a way to query TSR in a silverlight application.  Will the geocode service take a TSR value?
KevinSesock
The easiest way would be to have this as a feature layer. If you can get your STRs, plus quarters in as a grid in a layer, this will be the best method. As for programmatically, it is possible, but it's ridiculously complex, especially considering that there will be quads that aren't actually quads.
If you need to drill up, or combine multiple PLSS items, you'll need to use a recursive algorithm to figure it out. For example, if you have a user that selects the center of a Quarter 3, that would be a Quarter 2. And on up the PLSS hierarchy.
KevinSesock
I don't know if this is still relevant, or if you're even paying attention, but I'm working on an ASHX header file that will replace an old VB6 CGI program we have to convert between Lat Longs and PLSS. This crummy old VB6 program is dying (and about to take our Apache server with it), so I'm rewriting it using C-Sharp in an ASHX file. Our old system queried against a MySQL database that contained the Sections, Townships, Ranges, and all the way down to 10 acre tracts. That MySQL database is pretty out of date too, and the program doesn't always return accurate data. This new system will query against an ArcGIS server (using SOAP)
We have an issue in some of our web applications that if a user selects a 10 acre tract, we need to return a lat-long (just the centroid of the 10 acre tract) knowing full-well that's not terribly accurate, we still would like to have the center, hence the "conversion" from PLSS to lat longs.
But ultimately, if you still need something like this, if you have the service in ArcGIS server, it's not too terribly difficult to do. Just Query for the legal description you need, take that polygon and get the centroid of it (for our SOAP service, lacking a Centroid option, we're using GetLabelPoints). So really, to do this all you need is a Query.
