Im trying the AppStudio 3.2 / Esri.ArcGISRuntime 100.4 on Windows 10.
Im not being able to set the following path to a TileCache
"C:/Users/rpintos.ICA/ArcGIS/AppStudio/Data/93c17bd6406d48b584aa96970e9b0aa2/Uruguay.tpk" After the path is set, onPathChanged is executed but the property path doesnt change.
Something similar happens with a PortalItem object executing
fetchData("C:/Users/rpintos.ICA/ArcGIS/AppStudio/Data/93c17bd6406d48b584aa96970e9b0aa2")
I get the following error
Error in portal item: File path must be specified to fetch data.()
I also noticed that in the last framework release they solve the following bug
-BUG-000116279 Cannot create TileCache from a path on Linux when conf.xml file uses mixed case
It just says on Linux, but what happen in Windows? I haven tried it on Android and on iOS neither.
Path changed signal works for me. Try this code
property string dataPath: "C:/Users/<username>/ArcGIS/AppStudio/Data/"
Basemap {
// Nest the ArcGISTiledLayer to add it as one of the Basemap's baseLayers
ArcGISTiledLayer {
TileCache{
path: AppFramework.userHomeFolder.fileUrl(dataPath + "/SanFrancisco.tpk")
onPathChanged: {
console.log(path)
Basemap {
ArcGISTiledLayer {
TileCache{
onPathChanged: {
console.log(path)
Thanks! Now is working!
An other question related to the PortalItem object.
Do I have to specify the whole path with the filename and tpk extension like .../Uruguay.tpk? Because I remember using the old Qt Sdk Runtime 10.2.6 and specifying just the folder name was enough.
Thank in advance!
I have just tried it and yes, you have to specify the name and extension of the file.
What I see when it starts downloading is that the progressPercentage is always 100. That seems to be wrong
I attach to
onFetchDataProgressChanged
this is the log that I get
(First log)
qml: {"objectName":"","objectType":"NetworkRequestProgress","error":null,"objects":{},"bytesReceived":"0","bytesReceivedAsInt":0,"bytesSent":"0","bytesSentAsInt":0,"estimatedFinishTime":null,"progressPercentage":0,"startTime":"2018-12-29T16:56:13.083Z","totalBytesToReceive":"0","totalBytesToReceiveAsInt":0,"totalBytesToSend":"0","totalBytesToSendAsInt":0}
(Second log)
qml: {"objectName":"","objectType":"NetworkRequestProgress","error":null,"objects":{},"bytesReceived":"83665","bytesReceivedAsInt":83665,"bytesSent":"0","bytesSentAsInt":0,"estimatedFinishTime":"2018-12-29T16:56:13.341Z","progressPercentage":100,"startTime":"2018-12-29T16:56:13.083Z","totalBytesToReceive":"0","totalBytesToReceiveAsInt":0,"totalBytesToSend":"0","totalBytesToSendAsInt":0}
(N log)
qml: {"objectName":"","objectType":"NetworkRequestProgress","error":null,"objects":{},"bytesReceived":"115543108","bytesReceivedAsInt":115543108,"bytesSent":"0","bytesSentAsInt":0,"estimatedFinishTime":"2018-12-29T16:57:27.207Z","progressPercentage":100,"startTime":"2018-12-29T16:56:13.083Z","totalBytesToReceive":"0","totalBytesToReceiveAsInt":0,"totalBytesToSend":"0","totalBytesToSendAsInt":0}
In the second one, the percentage is already 100.
