Cloud Make fails
785
05-28-2020 01:31 AM
KamranYusaf1
When trying to build my apk using the cloud make it fails and the only error message that it shows is 'Failed'. The keystore file has been used before to sign the app. As it is an update to an existing app i need to sign the apk with the same keystore file. Do you have any logs or anything that could help me find out why the build fails?
Best regards
Kamran
Tags (3)
ErwinSoekianto
Kamran,
I am seeing this error message on the builds from this username agol.ig.ky
============================================================ Certificate Check ============================================================
appBuildId is 122317 platform is androidarm64
builddir is /home/appfactory/buildslaves/appfactory-slave-androidarm64-1/current-androidarm64/build
Android keystore could not be opened, perhaps invalid or password was incorrect
keytool error: java.io.IOException: Keystore was tampered with, or password was incorrect
at sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:780)
at sun.security.provider.JavaKeyStore$JKS.engineLoad(JavaKeyStore.java:56)
at sun.security.provider.KeyStoreDelegator.engineLoad(KeyStoreDelegator.java:224)
at sun.security.provider.JavaKeyStore$DualFormatJKS.engineLoad(JavaKeyStore.java:70)
at java.security.KeyStore.load(KeyStore.java:1445)
at sun.security.tools.keytool.Main.doCommands(Main.java:823)
at sun.security.tools.keytool.Main.run(Main.java:366)
at sun.security.tools.keytool.Main.main(Main.java:359)
Caused by: java.security.UnrecoverableKeyException: Password verification failed
at sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:778)
... 7 more
Thank you,
Erwin
by Anonymous User
Not applicable
HI Erwin,
How we can resolve this issue? I am having similar issue here https://community.esri.com/t5/arcgis-appstudio-questions/error-during-cloud-make-for-android/m-p/107... , do you know how to resolve it?
