Hello Meredith,
I'm not sure if I understood exactly what you're trying to do here but it's most likely that the existing tables you drag and drop probably are not multi-feature type and may be that's why you can't see the [AreaDesc].
The [AreaDesc] is used to identity the description of the site for the variables below. For example:
So if you simply want to display the site information for individual sites, the best option is to use the General data format:
If you still want to create a multi-feature table but don't want to see the area description fields on the top, you can simply clear the cells:
Based on the property of this table, merging the fields will break the report and variables returned for each site. Please give me more details if I misunderstood your question.
Thanks for contacting the Business Analyst Team,
Fasil T.
