Bringing in Polylines as Shapes
515
07-27-2023 11:12 AM
MattOlsen
New Contributor III
Hi everyone.
I'm looking for a workflow to import closed Polylines in AutoCAD as shapes in CityEngine.
I found this video, in which shapes from Sketchup are imported into CityEngine using the KMZ format. When I try to do the same thing, the shapes come in as highly triangulated models. When I use 'Convert Models to Shapes' they merge together.
Has anyone found a clean way to do this?
https://www.youtube.com/watch?v=Plncupf4FA8&t=963s
DevinLavigne
Occasional Contributor III
Matt what exactly are you looking to do? What are the lines for? Will they create a fill/shape?
DevinLavigne
@MattOlsen just checking in - your screenshot is my work FYI
MattOlsen
New Contributor III
@DevinLavigne
Thanks for following up on this. As you suggested, I wanted a shape that I can assign CGA rules to in the same way as a Lot.
In the end, I found a solution - by creating a HATCH from the shapes, converting to a surface (CONVTOSURF), then converting to a mesh (MESHSMOOTH) - saving a DWG and importing into CityEngine.
DevinLavigne
Sounds good. Yes I was going to say bring them in as fills.
