City Engine Get Object attribute
3058
07-24-2019 07:05 AM
JohnEsther2
City Engine Get Object attribute to use as the rule default is not working.
attr streetWidth = getObjectAttr("width")
used to work perfectly but now in ce 2019.0 it is telling me that:
Unused function:streetWidth
No such function: ? getObjectAttr(a:str)
what is the issue?
CherylLau
getObjectAttr() does not work in cga rule files.  It is meant to only work in layer attribute code, which you can see in the Inspector when selecting a layer.  Code can be manually entered here, but it is more likely that it will be automatically entered here when connecting rule attributes to layer attributes.
L R's suggestion is a good way of getting values from an object attribute into a rule attribute with a different name.  I would go with this.  However, I want to describe another method so that I can give an example of how getObjectAttr is used.
Another way of doing this would be to connect your rule attribute to the object attribute through the layer.  Click on the drop down box next to your rule attribute in the Inspector and select Connect Attribute.
Then, connect through a layer attribute, and select the layer and name of the object attribute.
Then, if you select the layer, you'll see that the Layer Attributes section in the Inspector contains the code:
attr a = getObjectAttr("b")
Note: getObjectAttr() will most likely be deprecated soon to be replaced by separate functions for floats, strings, and bools.  The above automatic behavior is expected to work, but the code generated will use the new functions instead of the deprecated one.
LR
Try
attr quack = "" # this is your object attribute, might want to @hidden
attr whatgoes = quack
@StartRule
 Lot -->
 	 print(whatgoes)
JohnEsther2
Thanks L R. That was helpful. this will enable me to script the attributes with python
CherylLau
