I made an even simpler example for you, which works for me. Does this work for you?
1) Create a new scene
2) Draw two rectangles
3) Add an object attribute called type to both shapes and set one shape's value to "residential" and the other shape's value to "office". (Inspector -> Object Attributes)
4) Apply this rule to the shapes.
attr type = ""
Lot -->
extrude(10)
report("Type", type)
5) Note that, in the Inspector, the rule attribute called 'type' is connected to the object attribute called 'type'. If it is not connected, connect them. Click on drop down arrow next to type -> Connect Attribute -> Object attribute. Also note that the report Type appears in the Reports section of the Inspector with the correct value for each shape.
6) Select both shapes
7) File -> Export models -> Esri Scene Layer Package -> Make sure 'Emit Reports' is checked -> Next -> Feature Granularity = One Feature Per Shape -> Finish
😎 Right click on slpk file in models folder -> Share As -> Upload package to my ArcGIS Online or Portal account -> Share
9) In Navigator, click on second icon along the top to go to your account and see the slpk you just made. Right click -> Open in browser. Or, sign on to ArcGIS Online in your web browser and view your Content to see the slpk file you just made. Select this file.
10) In the browser, in your ArcGIS Online account, click on the slpk file -> Publish -> Open in Scene Viewer
In the Scene Viewer, when a building is selected, the type reported is also displayed in the popup window.
