No, sorry, this is not possible if the data extent is in fact too large.
There is a limit to the extent of the scene that can exist, and this limit is about a couple hundreds of kilometers, which should be sufficient for large scale cities. If the data extent is larger than this limit, then the data cannot be imported into a single scene. If the data extent is not so large but it is more than a couple hundred kilometers away from the existing data in a scene, then this will also not work.
If it is an option for you, you could try to make multiple different scenes for the data. If you can put your data in a FileGDB, then when importing the FileGDB, you can specify the extent of the data you want to download.
