Easiest way to add textures/maps
1292
01-10-2013 07:12 AM
NicoleHanson
New Contributor III
What's the easiest way to add images or maps to CE?  I just want a small area, but I can't seem to figure it out.  Please help!
JoanneO_Brien
Do you use ArcGIS? The easiest way there is to crop a small area and convert the raster to jpg or png then in CE import the file as texture import. You can use the texture import for any image but if it comes from ArcGIS you can have it georeferenced correctly.
NicoleHanson
New Contributor III
I do use ArcGIS.  I converted the raster to jpg, but when I bring it into CE, it doesn't look right.  Well, it doesn't look like much of anything.
BradyHoak
THere might be other ways to get this to work but this workflow is what I use. First make sure you know the projection of your data and have it all in the same projection.
From ArcMap
For the imagery:
- use the clip raster tool to create a new raster dataset to a specific polygon rectangle that you previously created for the extent of your scene
- export out the layer to a tif with these settings: no data is 0, check use renderer and force rgb, save as tif, 8 bit
- export to a folder
- copy/paste this folder into a folder such as your images or data folder in your CE workspace
For the elevation:
-same as imagery export but don�??t use RGB renderer, export as 8 bit tif
In CityEngine, make a new scene (right click, new scene) but do not choose a coordinate system at this time. Then drag in the elevation tif file and CAREFULLY set the projection to match what you know it should be. CE will then ask you to also set the scene to this same projection and say yes. Choose your imagery and its projection.
Wait a few moments, depending on the size of your image (it can take about 15 seconds if very large), and then right click on the scene and press 'f' to zoom to it if it isn't already show in the view window.
NicoleHanson
New Contributor III
Thanks Brady-
I am trying that way, but it won't let me clip from the base imagery.  Is that not able to be clipped down?
Nicole
