get map data ok box greyed out
4381
15
01-30-2017 02:16 PM
KimberlyStuart
Open Street Map opens with Get Map Data, but the OK button is greyed out.  I am logged in -
Please advise.
CherylLau
Did you search for a place and drag a rectangle around the area you want to download?  The OK button is grayed out until an area is selected.
BrianMorrison1
New Contributor II
I have the same problem, I am logged in, and dragged a rectangle around the area I wanted to download , and the button was still greyed out , did you ever get a resolution to this?
DavidKossowsky1
Which version of CityEngine are you using?
CherylLau
Could you please provide a screen shot and step by step instructions on how you got to the screen shot so that we can try to reproduce it?  Did you start with a new scene?  Please also include the version of CityEngine that you are using.
BrianMorrison1
New Contributor II
I was able to get it resolved, I had pre-defined the coordinate system of my project, as a result the import of the data did not work.
neculacristian
THAAANK YOUUU!!!!!
Luiz_AmadeuCoutinho
Occasional Contributor III
I got the same problem yesterday.
My project was using a Local Coordinate System (UTM Portugal).
Solution: Create a new projec without Coordinate System or use Geographic Coordinate Systems and the button will work again.
AprilChipman
I had the same problem in CityEngine 2016.1. Creating a new City Engine project and *not* defining the projection finally allowed me to import data from OSM.
TokyoSteve
New Contributor II
Having this issue now. ALso not defining it but it sets it to a default set. Did you end up setting it to Preferences>secene>Scene coordinate system>choose>No Projection > Raw data in feet/meters ?
