How can I delete the terrain to get a flat city?
1011
05-28-2017 06:13 AM
RebeccaM
New Contributor III
I would like to make the Paris example (http://www.arcgis.com/home/item.html?id=a90039c38043481889c06d9ba4a1e215) completely flat, so all the buildings and streets are on the same level. How do I do that?
I have ...
deleting the height map / terrain from the file server, but that has not worked, neither has setting
attr elevation = 0.
Can anyone help?
RebeccaM
New Contributor III
Problem solved, it seems to have worked with:
selecting all objects > Graph > Align Graph to Terrain > choose Align Function Project All > Heightmap choose y=0 > Offset choose 0.2.
Thank you
AbhishekSobbana
New Contributor II
You can select all the objects and use "align shapes to terrain" option and select y=0 this will bring everything to one level,
I hope this helps you.
Regards
Ab
RebeccaM
New Contributor III
Hi Ab, thank you.
This option is not accessible:
Any idea what's wrong?
AbhishekSobbana
New Contributor II
In your case I guess you have to choose "Align graph to terrain". Select all the objects, right click on the viewport and click "Align graph to terrain", set y=0
Cheers
Ab
RebeccaM
New Contributor III
Thank you
