I am using the sample prt4cmd from the SDK and getting this error. I am using the sample data (candler.rpk + candler.obj) provided.It is complaining that I need to recompile the CGB. How can I do this?
This is the error message:
C:\esri-cityengine-sdk-master\examples\prt4cmd\install\bin>prt4cmd -s 27000@Chris-Dev -f CityEngAdv -l 3 -g C:/esri-city
engine-sdk-master/examples/prt4cmd/install/bin/data/candler_lot.obj -p C:/esri-cityengine-sdk-master/examples/prt4cmd/in
stall/bin/data/candler.rpk -a ruleFile:string=bin/candler.01.cgb -a startRule:string=Default\$Lot -e com.esri.prt.codecs
.OBJEncoder -z baseName:string=theCandler
[2016-Feb-22 11:14:48.494413] [warning] CGB file contains warning 'Potentially problematic CGAC version 1.2 : recompilin
g with current CGA Compiler (1.5) is recommended.'
[2016-Feb-22 11:14:48.501405] [error] OBJEncoder::encode failed, exception caught: 'Unknown rule.'
[2016-Feb-22 11:14:48.504408] [error] Status code = 37 = Unknown rule.
Ok the fix is to import the rule and "share as" and the rule is updated.
Now the problem is the error OBJEncoder::encode failed, exception caught 'unknown rule'.
Dear Christian,
Kindly refer the links below and try to follow. Hope it will solve your purpose.
esri-cityengine-sdk/examples/prt4cmd at master · Esri/esri-cityengine-sdk · GitHub
esri-cityengine-sdk/prt4cmd.cpp at master · Esri/esri-cityengine-sdk · GitHub
https://media.readthedocs.org/pdf/turbogears/latest/turbogears.pdf
The PDF will help you to configure and work properly.
Thanks and Regards
Abhishek Rathi
