3D SME, new to CE 2014.
Am trying to import a simple dxf file into CE and have tried the wizard (File >> Import >> Import Src >> DXF Import >>)
Browse to file (r12 dxf). Options on = Run Graph Cleanup and Create Street/Intersection Shapes.
Finish > does nothing, apparently.
When I click Next, the Cleanup Graph dialog shows, but the only options available here are Back and Cancel.
Changing the merge distances does not activate next or finish.
So no, I have not worked through the learning tutorial, because the videos do not seem to match the CE version I have, and as you can tell, I am having problems with a simple import.
Also have tried file drag-n-drop from windows to CE, but that doesn't work at all - the only option is to cancel.
I can't tell if the dxf should be able to be imported into the streetnetwork layer, or some other layer (data??). Pointers to getting this working will be appreciated!
Thx
