Multiple geotiffs as terrain texture
2131
06-18-2014 02:47 AM
SivaKanesh
I'm trying to export shp and terrain data from ArcGIS into CityEngine 2013.  The terrain is exported as a height map tiff with the aerial photography as the texture.  The problem is that multiple tiff AP tiles makes up the texture, but I can only use a single image as the texture in CityEngine.  How can I apply multiple tiles as the texture for the the terrain?
Do I need to join them into one single image?  Has this changed in CE 2014?
MatthiasBuehler1
hi ..
both the dem ( elevation map ) and the satellite picture must be 1 image each. tiles are not supported.
this did not change in 2014.
make sure you also read this thread:
http://forums.arcgis.com/threads/54072-textures-raster-files-concepts-in-CityEngine-ArcGIS
ok ?
Matt
