Right, left, or even back sides facade ?
1476
01-30-2019 02:46 AM
BilalMustafa
New Contributor III
Hi all,,
while i'm trying to learning CE by using the tutorials i passed by the facade modeling, facade wizard & Advanced shape grammar and i have the following Question:
*they are all talking about the front, Top.. Ground floor and upper floor... etc.
but what if i want to model the right side or the left keeping in mind the definition of the front facade?
by other words i want to apply  left,right or even back side facade model than different than the front facade is it possible or i have to use different application and more manual procedures such as google sketchup the import the . obj to the CE and apply texture ?
comp (f) { front : frontfacade | side: sidefacade | back: backfacade
thank you for your help
LR
Occasional Contributor III
You can comp left and right too.
comp(f){left: LL | right: RR | front: FF}
If it's a more complex building, you can use the polygon indices, like comp(f){0: AA | 1: BB | etc... }
LR
BilalMustafa
New Contributor III
L R thank you for your help!
i'm facing difficulties in multi-facade import,
i did the comp(f) and everything is going well
comp (f) {0:AA |1:BB |2:CC | 3:DD |4:EE| 5:FF|6:GG |7:HH}
then i apply facade to CC
CC-->
comp(f) { 2 : gen_Facade_AdvancedFacade.Facade }
also add some colors to different sides
AA-->color ("#0000FF")
BB--> color("#FF0000")
the Question is how Can i import  different facade.cga instead of color?
BilalMustafa
New Contributor III
Thank you guys i the engine is started!!   i found it
