Suggestion: Support for PBR texture maps
782
09-13-2018 02:54 AM
AbeleGiandoso
Hi all
I have a suggestion for the next version:
I was thinking, since now most render engine support PBR, wouldn't it be a blast to update the maps that CE can digest so that
- Base Color
- Roughness,
- Normals
- Metallic
and maybe (Height, Opacity, Emission and AO) are included?
I am not saying they should render correctly, just that there should be a "slot" for them, a dedicated UV set. So that you can plug in Substances outputs maps directly in CE and when you export the connections are already there and  it renders PBR correctly.
Base color, normal and Opacity are there already, so it would be like rearranging connections a bit and add a couple ones
What do you think CE people, is it something doable?
DanPatterson_Retired
A good spot to put suggestions is
ArcGIS Ideas
If it gains traction, then it might be implemented
AbeleGiandoso
Good point! I added it there
Abele
You might want to advertise this thread...
I will link this thread to the idea
https://community.esri.com/ideas/15532
