Texture shows in preview but not in viewport
1862
10-28-2014 06:47 AM
AlexandruVasile
Hi there,
I have made some modifications to a roof rule initially intended to randomly add a chimney.
I added a texture. The weird thing is that the preview shows me the roof with the texture,
I have attached a print-screen and the rule
by Anonymous User
Not applicable
I put your rule into my scene, and a couple of textures in the locations  as you do. I don't encounter your problem, unfortunately.
Here's some thoughts:
- I see no version in the rule, which should cause you to have a compiler error. What version of CE are you running?
- Sometimes I've had problems trying to apply textures from anything other than the assets folder.
- You are using absolute paths to the textures, which is not a great strategy in general.
So those are just thoughts, not solutions. If you can't figure this out, I would like to see the project file if possible. Please let me know if you do or don't solve this. I'm following this discussion now.
Chris
AlexandruVasile
I am using version 2014.0
So all I have to do is write in the beginning of the rule?:
version "2014.0"
Because if that is the case, it still does not work.
And to change to relative paths all I have to do is remove the project name from the path?
roof_tex= "assets/roof-texture2.jpg"
instead of
roof_tex= "MyFirstCity1/assets/roof-texture2.jpg"
I did that, no difference.
I also moved the texture to the assets folder, no difference.
by Anonymous User
Not applicable
Hmm. Since it worked on my machine, the next step is you dropbox me your entire project file, and I try running it on 2014.0, since I tried it on 2014.1. I would need the exact project as it stands so that when it is opened, it shows the building in question. No services except dropbox please. Let me know.
AlexandruVasile
I don't know what the issues was.
When I applied the rule to another footprint (another shape file), it worked.
Even though I initially applied the rule to a shape from one of the tutorials.
Thanks for the help:)
