trial version crashed, now license is invalid
882
12-19-2011 10:59 AM
KevinMcMaster1
New Contributor II
Hello, I downloaded and installed the trial version of CityEngine 2011.1 three days ago. Today it crashed with a "multiple errors" warning box. Upon restarting it, the license now appears to be invalid, as I get the license error box of "Please upgrade your license. License has been invalidated". I get the option of browsing to a license file, but don't know where to find the trial license file. I am running a windows 7, 64-bit machine. Any ideas? Thanks! Kevin
MatthiasBuehler1
hi Kevin !
this is odd ..
are you located in the US ? if so, please contact esri support (support@esri.com) and ask them for a Time Limited Full License / TRIAL extension, mentioning your issue.
if you are located outside the US, please find your local Esri Distributor and contact them, with the same inquiry. http://www.esri.com/about-esri/locations.html
you'll get access to the full installer (which has the Exporter also included) plus an Activation Code.
ok ?
KevinMcMaster1
New Contributor II
Thanks Matthias,
My ESRI regional representative hooked me up with a new trial license (with exporter activated) so I can continue to test the CityEngine software. Of course, now I'm running into all sorts of issues trying to get the exported model textures working with ArcScene 10, but I'll check the forum to see if anyone else has already blazed that trail.
Thanks again for your help!
Kevin
MatthiasBuehler1
hi !
great to hear you're up and running with the TRIAL !
make sure you see all the GIS related help resources here :
http://resources.arcgis.com/content/cityengine/about
check the gallery section !
cheers !
