Honour inverted colours in Collector
1543
02-16-2021 04:18 PM
Status: Open
James_OKane
New Contributor III
I enjoy using inverted colours on my devices when out in the field. For instance swapping black on white background to white on black background. It also saves power which is great when outside with max screen brightness. I attempted to do this on an iPad (using smart invert) running Collector but sadly it inverts everything in the entire app such as imagery. Given Collector is a field app it would be great if inverted colours worked as expected. I.e. Invert text and UI but not images or layers. Using correctly working inverted colours outside is remarkably good if you haven't tried it such as reading text in a browser.  This feature would greatly help those with poor or limited eyesight but would help anyone who works in direct sunlight. Ideally the feature would just work with an OS level invert however just a setting within Collector would be good too.
