Collector App (iOS) crashing
2433
5
03-13-2014 07:04 PM
LeehuLoon
I just set up a map to use on the Collector App and when I try to add a new feature the fields that I set up do show up. However when I select the first field to add text the app crashes. All the other features work and allow me to add text or a date or short integers. Any ideas why the app crashes?
RussRoberts
Esri Notable Contributor
Can you share the web map and service with some and I can take a look at what may be causing the crash.
Russ
LeehuLoon
Hello Russ:
Here is the web map...
http://bit.ly/NdDr8f
And here is the link to the service...
http://bit.ly/NdDDVh
Also, I had the same crash on another iOS device. Both iPhone 5s.
Thanks!
RussRoberts
Got them. Thanks! I will update this thread when I see what the issue could be.
Russ
RussRoberts
It looks like you are using a Unique Renderer set up on a field that has no values and when you try to use that field in the popup it is causing a crash. If you use a simple renderer which mirrors exactly what you would be using in the UV setup the app works correctly. If you want to try it out you can create a copy of the test service I made just follow these steps:
1) Go to ArcGIS.com and open your "My Content"
2)Click Create Layer
3)Use the option "From an existing URL" and put this in the text box - http://services.arcgis.com/dkFz166a8Pp3vBsS/arcgis/rest/services/Norman_Campus_Tree_Inventory_forums...
4)Go through the publishing wizard and you will create a copy of the service
Then you can add this template service to a map and do data collection on it and you shouldn't see a crash anymore.
Russ
LeehuLoon
Hello Russ:
Yes, it works perfectly now.
Thanks very much for your help!
