I have just tried to use continuous collection on one of my projects and have discovered that it is not working. The Continuous collection panel does not appear immediately (or at all) after having collected a feature. I did some testing , with other projects and other login profiles, and discovered that the problem is unique to this particular project. It has worked in previous iterations of this same project earlier in my testing phase.
As far as I was aware the continuous collection was no more than a setting at the app level. Is there potentially something that I could have done while building the map or data-set to prevent continuous collection? I am using Collector 10.3.1 on iOS. Any advice would be appreciated.
