Demo App or real?
1111
13
01-15-2013 12:40 PM
LukePhilips
New Contributor III
Is it possible to use this app with my own arcgis online account or arcgis server? It seems like the app is only a demonstration...
DavidAlford1
New Contributor III
I just sent you an invite to 2 of our maps. After I click on the link in my email, it seems to want to start up. I can see a blank map for a moment with the Collector tool bar at the bottom, but then it just quits loading and goes to a blank screen.
RussRoberts
Esri Notable Contributor
Could you also forward me a sample email with the two links in it? You can reach me at russell_roberts@esri.com
Thanks
Russ
BurlingtonStrachan1
I cannot find any to the point instructions on how to track the location of a data collector using the combination of Collector and Operational Dashboard.  Everything I have seen suggests at all you have to do is add a location tracking feature service to your map save it. Fire up operational dashboard add the map, and Bobs your uncle everything works fine.
But this is not the case.
Can someone direct me to where I can find clear instructions on the process, requirements, etc.
Using Arcgis Online (AGOL) Organization Account
Collector 10.2
Dashboard 10.2
BFS
RussRoberts
In our doc here are the steps for creating a location tracking layer and setting up your map to leverage the location tracking layer
http://doc.arcgis.com/en/collector/android/create-maps/track-where-collectors-went.htm
And in the Ops Dashboard help shows you how to deal with dynamic data like the location tracking layer.
http://doc.arcgis.com/en/operations-dashboard/windows-desktop/author/create-an-operation-view.htm
Hope this helps
Russ
