Does domain field appear in collector while editing?
2095
01-19-2016 01:23 PM
SergioDomenech_Zueco
I am working with a feature layer in #collector which has two fields: one with a subtype (JORNADA) and another with a dependent domain (ACTIVIDAD).
I can see both fields editing the web map in ArcGIS Online although the field with the domain is blocked. When I try to edit it in collector, my device shows me only the subtype field. The domain field only appears when I save changes.
Is there an option to show the domain field (blocked as in ArcGIS Online) while creating new features in collector? Thank sin advance! 🙂
RussRoberts
Esri Notable Contributor
The Collector app currently only shows editable fields in the editing popup. If a field is disabled for editing in the popup it will only show up in the popup displayed when viewing features.
Thank you very much for your help!
