Duplicate points being created in Arc Collector when copying feature
433
08-05-2021 05:41 PM
MarkReynolds
Hello
We are having some issues where we are finding duplicate points in the data when we copy a feature with the same data to a new location. We used the copy function regularly when we have the same or very similar attributes and just need to change one or a couple of fields from the previous point. The data is copying over to the new location but when we download the data the point is duplicated with the same data in the new location - both have the same time stamps, the only difference is that 1 pint will have a photo as an attachment. We are using Android App version 20.2.2 Build 2960.
Has anyone else run into this problem?
Bud
Notable Contributor
Did you end up finding any info on the cause or a solution? Were the time stamps exactly the same? Or were they roughly 30 +/- seconds different?
