Solved! Go to Solution.
We've got 2 iSXBlue II units out in the field this summer - so far we've been seeing ~0.7m accuracy. Since it uses SBAS I was worried we would loose the correction signal when we got too far north (survey running up to the North Slope in Alaska) but so far no issues.
Hi Craig,
We are having trouble connecting the iSXBlue II to our Trimble Juno. Do you have the pairing process documented?
Thanks, Jon
This guy works pretty easily - https://buy.garmin.com/en-US/US/oem/sensors-and-boards/glo-/prod109827.html
Only tested with iPad/iPhone with Collector
I agree with Anthony above, the Garmin GLO has been working a treat on our iPad minis with Collector 10.2.4.
Also tested with the Garmin Fenix 2 - works really well... Though need to try some long hikes in varying terrains/tree cover to see how it performs.
What kind of accuracy were you getting?
Every external GNSS unit will have different levels of accuracy. See what the venders are reporting on accuracy, but also collect some data on NGS control points or survey control to see what you are collecting. In addition, depending if you have access to SBAS, accuracies vary. With the SX Blue and SBAS I was recording submeter data. Better yet is that the lines are very straight, and the data collection accuracy is repeatable.
Which OmniSTAR service were you using? (If you were)
Ignore me. You said SBAS.
