Are you saying the Geneq blue worked with Collector?
Has anyone tried the Garmin GLO Bluetooth?
I have used the Garmin GLO clipped to the bill of my ball cap (clip sold separately) and it worked great with a disconnected Collector map.
Thanks Dominick for sharing your experiencie, can you tell me if you have tested the Glo with an IPad wifi? can the Collector get the coordinates offline?
I haven't tested the GLO specifically, but I can confirm that a wifi-only iPad will hook up to and use a bluetooth GPS while offline.
That said - there appears to be a bug in iOS 8.3 with the use of some external bluetooth GPS units. You might keep this in mind and stick with iOS 8.2 to be safe.
We just purchased a GENEQ SXBLUE II. I just received it yesterday. We are in the process of installing the app on our iPads. My email is tkukitz@cityftmyers.com. I will post info here when I find out how it works.
We had done some testing comparing a GLO on a known fixed locations using the collector application on a iphone 5c in an urban environment. The GLO was between 1-4 feet and iphone without the GLO was 2-10 feet. We have found the combination of a 7 inch tablet running collector in disconnected mode, and using the GLO, a very cheep way to collect high quality GPS points in the field.
We are about to get an SX Blue II demo. Very interested in this subject!
Kenan,
I was able to use a SX blue with great results. I could Bluetooth it to my android phone, and to an older Trimble Juno for use in ArcPad. I have a friend who uses it with a large Samsung device with collector, and he really is happy with it. Good luck to you. Craig
Awesome! What model did you use and what accuracy were you getting?
