I published a hosted feature layer with ArcMap that includes a point, line, and polygon layer for field data collection. This layer has worked fine in Collector Classic for data collection, and there is no issue in Classic with being able to tap the feature to view its attributes/pop up or to edit the feature. However, this is not the case in the New Collector. In this case, once you submit a feature, you are unable to select or edit anything in the layer. This behavior has happened in several different web maps that are used offline.
The user that is trying to edit the data is a Creator user type with a Publisher role. I also confirmed that editing is enabled for the feature layer where editors can add, update or delete features.
Any idea what could be causing this behavior? Thanks in advance for any input!
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
