How to have a map available to "My Organisation" by default?
3073
08-31-2014 08:10 PM
GISSupport3
G'day Again!
I am using ArcGIS Portal.
I have Portal set to automatically create a named user on login.
I would like everyone in "My Organisation" to use some maps via Collector for ArcGIS immediately after login.
I have shared the map(s) with "My Organisation"
Via a web browser, I can see the above shared maps in the Gallery.
Via Collector, I can not see the maps, unless I also add the user to a group.
What have I missed?
What is the workaround?
PS scheduling a task to run every XX minutes to add users to a group is undesirable,
AndreeaAmbrus
As far as I know, Collector for ArcGIS reads only maps located in a group and maps created by you (as the user). I am curious too to find out if there is way around this requirement.
