"Layer Not Loaded" (a server with the specified hostname could not be found) error message appears while opening map in Collector. I have an editable SDE feature class published as a feature service through ArcGIS Server. Then I created a map through AGOL for use with Collector, using this feature service. When I go to open the map in Collector the error message appears and I can not view my data layer. Any help would be appreciated, Thanks!
The full error message:
Layer Not Loaded
Unable to load layer (___) from (___).
A server with the specified hostname could not be found.
