I have a few layers set up (in the utility network schema) pulling from a SDE published service that has related tables set up as inspection tables. In pro I can click on the feature and see the attribute and the related table attribute to that feature. Pro 2.6.3, Enterprise 10.8.1, Portal 10.8.1.
I want to be able for field crew to see the related tables (inspections) and add data. However I can't get it to display in collector. In my web map I have the enabled popups selected in all my layers and tables along with all the fields, but when I select the feature (hydrant) in Collector I only see the feature data and don't get any link of my related inspection table to see my existing data or the ability to add new data.
Is there something special that has to be checked when shared to a service in order to allow the editing and viewing in collector? I found this article https://support.esri.com/en/technical-article/000015422 about using the Global IDs and GUIDs as the relationship fields for collector. Is this a requirement? My relationship fields is base off two text fields. The layer has an attribute rule to give it an unique number in its field so it is functioning properly when editing in Pro. So will collector not work correctly if my relationship is not based off the Global IDs?
