Hi Amanda,
You should be able to set this in the web map. After you click on 'Edit', you should see 'Manage' at the bottom of the Add Features pane. After clicking on Manage, click the dropdown next to the layer > Properties:
You will then have the ability to set the edit tool:
I believe this will rollover to Collector, but haven't tested it, yet.
