I need to create a workflow for Collector in which different users work with the same map but when they open it they only see the content that is relevant to them.
I thought about incorporating a username field into the table and then using it as a #filter.
It is possible to generate this filter (possibly through AGOL Assistant) to take into account this dynamic value?
Thanks.
Definitely needed I would say! We are also trying to find a way to share the same map with users but each should only see the features of their administrative area.
I have the same problem with Survey123 and other applications.
In my case, I want each user to have access to their data and team leaders to access data only from their teams.
And eventually a team leader can create a record that is visible to one of his operators, without having to use that user's account.
This can be done but you need to create several views and several apps.
This is really urgent for those who develop large-scale projects.
There are many institutions and companies that need this resource...
It's still dark here...
Compliments
