I'm going to assume the title of your thread is what you mean, not whats in the body of it.
My guess is you want to export just the x/y fields (and perhaps some others) from the resulting feature class you created by geocoding into a table.
Short answer: Yes!
In ArcMap double click your geocoded_results feature class and go to properties. In the fields listing, turn off all the but the fields you want. Then open the feature class attribute table. It should be displaying just those one you left checked. Go to options on the bottom of the table window, select data and export.
Oh sorry, I meant I wanted to export my geocoded points from community analyst (either in a table or layer) so that I could put them into ArcMap. Basically I'm just trying to avoid downloading a bunch of street files for different counties.
Hi Teresamaria, At this point it is not possible to export out geocoded points (in table or layer form) from Community Analyst.
