ArcGIS Companion: Option to disable “Recents” in Mobile App
887
05-10-2022 05:17 AM
ytmartins_imagem
New Contributor II
Hello Esri Community 👋👋
ArcGIS Companion: Option to disable Recents view in Application Home Layout.
Need: A customer requested this possibility to reduce the cognitive load for the (non-technical) person not to get confused when opening the application, so as to consume the right information.
Solution Suggestion: In the application when clicking on Settings > Discover > could have the option Show ArcGIS Recents (with option to enable/disable).
I sent attachments to illustrate the steps.
Thank you very much! Success!
Yuri Tomaz Martins
