Reset Selectors to defaults
2346
6
07-11-2019 11:39 AM
Status: Implemented
KevinMayall
Occasional Contributor III
In the Side Panel, provide an option to let the Dashboard user reset all of the Selectors to their default values.
6 Comments
KoryKramer
Hi Kevin - since you wrote "Dashboard" I'm assuming this is an Operations Dashboard idea.  Is that correct?  I went ahead and added that as the category.  Please correct if needed.
KevinMayall
Sorry, yes it is Operations Dashboard.  Thank you!
JohnGargiulo
Kevin, great idea from 2 years ago!  Any prioritization on this one ESRI?
by Anonymous User
At the June 2021 update to Dashboards, you can now allow users to clear their selector inputs at run time. Not a "reset all", but should help with this use case.
KevinMayall
patrickb
As noted by @Kevin, new setting to allow dashboard reset was added as part of the November 2022 update of ArcGIS Online. All things remaining equal, it will be picked up by ArcGIS Enterprise 11.1.
