Can Operations Dashboard be configured to work with ArcGIS Server?
1146
03-21-2013 11:53 AM
ScottTompkins2
We operate using the ArcGIS Server platform, I would really like to incorporate the capabilities of Operationns Dashboard into our web solution. I would like to use ArcGIS for Server instead of AGOL. Is this possible? If so how would I go about completing this task?
SteveBratt
New Contributor III
I have been interested in the same question and my understanding is as follows:
If you have AGOL you get Operations Dashboard for free.  No AGOL, no OD.
That said, within AGOL you can configure AGOL to point to your internal ArcGIS Server.  AGOL has the concept of a "webmap" (terrible name) which is conceptually like a web version of an MXD.  Within OD you pull the "webmap" or web MXD from AGOL and this has pointers (and connection info) to your internal ArcGIS Servers (and to any maps you want from AGOL or elsewhere).
Thus you can use Operations Dashboard against your own AGS's, but not without an AGOL license for each user.
