Create Dynamic Date Range Expression that shows Date Range of Displayed Data
517
04-06-2023 11:17 AM
WalidAlmasri1
I've created a dashboard where the data displayed is on a rolling 30-day time frame.  The data updates once a day, with the previous days data being the most current.
Is it possible to create an expression that displays the date range of my data every day it is refreshed?  Similar to the example below?  Area in yellow would change based on the date range of my data.
My time field looks like this:
Thank you!
Omar_A
by Esri Contributor
Hi Walid,
Try this an Arcade expression to generate the desired date range.
var currentDate = Date()
var endDate = DateAdd(currentDate, -1, 'days')
var startDate = DateAdd(endDate, -29, 'days')
var startDateFormat = Text(startDate, "MMMM d, yyyy")
var endDateFormat = Text(endDate, "MMMM d, yyyy")
return startDateFormat + " - " + endDateFormat
WalidAlmasri1
Thanks!  This definitely helps, but I am trying to add the date range of the data in the title of the dashboard.  Is that even possible?
