execution error - invalid parameter - JoinLayerFieldsToTable after successful GroupBy
1277
01-12-2024 05:12 PM
ChrisGiamarino
New Contributor III
I have a feature class with 1425 rows and a table with only 10-15 jurisdictions. I am trying to GroupBy the feature class and then JoinLayerFieldsToTable. I've successfully grouped the 1425 rows, but when I try to join them using the esri arcade GitHub documentation, I get an execution error.  My team and I want to create a bar chart in Dashboards with 5 numerical bars by jurisdiction.
Here is the code sample:
// Write an expression that returns a FeatureSet.
// Documentation: https://arcg.is/3c419TD
// Samples: https://arcg.is/38SEWWz
var portal = Portal("https://marincounty.maps.arcgis.com/");
var polyFs = FeatureSetByPortalItem(portal,"1112f6fa268c48948093050fe0fc0c44",0,["*"],true);
var tablefs = FeatureSetByPortalItem(portal,"1093d97dbe43474b96d09b701d9672a1",["*"], 0,false)
// create grouped table variable
var polyGroup = GroupBy(polyFs,
['Jurisdiction'],
[{name:'SumPotentialCompTons', expression: "PotentialCompTons", statistic: 'SUM'},
{name:'SumPotentialMulchTons', expression: "PotentialMulchTons", statistic: 'SUM'},
{name:'SumPotentialROWPTons', expression: "TotPotentialROWPTons", statistic: 'SUM'}]);
var features = [];
var feat;
// Populate Feature Array
for (var t in tablefs) {
    var tableID = t["Jurisdiction"]
    for (var p in Filter(polyGroup, "Jurisdiction = '${tableID}'")){
        feat = {
            attributes: {
                FeatureID: tableID,
                SumPotentialCompTons: p["SumPotentialCompTons"],
                SumPotentialMulchTons: p["SumPotentialMulchTons"],
                SumPotentialROWPTons: p["SumPotentialROWPTons"],
                Population: t["Population"],
                ProcurementTarget: t["ProcurementTarget"],
    Push(features, feat)
Console(p)
var joinedDict = {
    fields: [
        { name: "FeatureID", type: "esriFieldTypeString" },
        { name: "Name", type: "esriFieldTypeString" },
        { name: "SumPotentialCompTons", type: "esriFieldTypeDouble" },
        { name: "SumPotentialMulchTons", type: "esriFieldTypeDouble" },
        { name: "SumPotentialROWPTons", type: "esriFieldTypeDouble" },
        {name: "Population", type: "esriFieldTypeInteger"},
        { name: "ProcurementTarget", type: "esriFieldTypeDouble" },
    'geometryType': '',
    'features':features
// Return dictionary cast as a feature set
return FeatureSet(joinedDict);
Could anyone help me troubleshoot and resolve the issue? I'd really appreciate it. We have each jurisdiction populating the feature class with field maps, so we don't want to hard code the population and procurement target values. I am unfamiliar with Console() or seeing logs as to what is happening.
ChrisGiamarino
New Contributor III
nevermind, after some troubleshooting and referencing this solution response post from @jcarlson, I got my code to work. Here is the solution:
var tablefs = FeatureSetByPortalItem(portal, "1093d97dbe43474b96d09b701d9672a1", 1,["Jurisdiction","Population","ProcurementTarget","uniqueID"],false);
// return(tablefs)
['Jurisdiction'],
// create empty features
var features = [];
var feat;
// populate feature array
for (var t in tablefs){
  for (var p in Filter(polyGroup, "Jurisdiction = @tableID")){
    feat = {
      attributes: {
        FeatureID: tableID,
        PotCompTons: p["SumPotentialCompTons"],
        PotMulchTons: p["SumPotentialMulchTons"],
        PotROWPTons: p["SumPotentialROWPTons"],
        TargetRemaining: Round((t["ProcurementTarget"] - p["SumPotentialROWPTons"]),2),
  Push(features,feat)
var joinedDict = {
  fields: [
    { name: "FeatureID", type: "esriFieldTypeInteger" },
    { name: "PotCompTons", type: "esriFieldTypeDouble" },
    { name: "PotMulchTons", type: "esriFieldTypeDouble" },
    { name: "PotROWPTons", type: "esriFieldTypeDouble" },
    { name: "Population", type: "esriFieldTypeInteger" },
    { name: "TargetRemaining", type: "esriFieldTypeDouble" },
  'geometryType': '',
  'features':features
// return dict as feature set
return FeatureSet(Text(joinedDict));
ChrisGiamarino
New Contributor III
Hi, I am still having issues with this expression. I'd like to join a table to a GroupBy table (polygon feature layer) using JoinLayerFieldsToTable. I am able to import the Feature Layer and Table using FeatureSetByPortalItem. I am also able to GroupBy the 'Jurisdiction' column for my feature layer. I am just unsure where I am going wrong with the populate feature array, joining dictionary, and successfully returning the dictionary as a FeatureSet. Please see source code below. Again, I appreciate any helpful insights or solutions. Thanks.
['Jurisdiction'],
var features = [];
var feat;
  var tableID = t["uniqueID"]
  for (var p in Filter(polyGroup, "Jurisdiction = "+tableID)){
    feat = {
      attributes: {
        FeatureID: tableID,
  Push(features,feat)
var joinedDict = {
  fields: [
  'geometryType': '',
  'features':features
ChrisGiamarino
New Contributor III
// return(tablefs)
['Jurisdiction'],
var features = [];
var feat;
    feat = {
      attributes: {
        FeatureID: tableID,
  Push(features,feat)
var joinedDict = {
  fields: [
  'geometryType': '',
  'features':features
