I am trying to test creating an operation dashboard and noticed that the bar chart feature count is not accurate.
All of the values in the bar chart is incorrect, Citrus which should be 5,314 is showing as 607. I am wondering is this is because not all of the points are not displayed in the web map because they are cluttered together (there is a warning in the web map that not all of the points are displayed on the full layer extent), which is still weird because the total in the summary (i.e. 12,706) is correct. The point data that I am using covers several counties and are concentrated at certain areas, would the Bar Chart Widget not work well for feature counts in this case?
