I'm currently creating a toolbox where I have ~50 input parameters for each script and I'm having a lot of trouble keeping everything in order despite the actual script being not too complex. Right now I'm using a custom function that allow me to get the index number of a parameter by giving its name in the parameters menu, but this is certainly slowing down my scripts. I could probably find a way to just have it call the list of parameters once at the https://omegle.onl/ beginning of the script and assign them later, but I'd really just like to use a built in function if that's an option.
Therre isn't a built in method other than to assign the name
Parameter—ArcGIS Pro | DocumentationParameter—ArcGIS Pro | Documentation
Not builtin, but for my Python toolboxes, I usually use a small function that converts a list of arcpy.Parameter into a dictionary with the parameter names as keys and the parameter objects or their value attributes as values:
def parameters_as_dict(parameters, only_values=False):
if only_values:
return {p.name: p.value for p in parameters}
return {p.name: p for p in parameters}
class Tool:
def updateParameters(self, parameters):
par = parameters_as_dict(parameters)
# parameters[15].enabled = False
par["p_name"].enabled = False
def execute(self, parameters, messages):
par = parameters_as_dict(parameters, True)
# x = parmeters[15].value
x = par["p_name"]
You can do the same thing in the ToolValidator class and in the execute script of a script tool.
class ToolValidator:
def __init__(self):
# self.params = arcpy.GetParameterInfo()
self.params = {p.name: p for p in arcpy.GetParameterInfo()}
def initializeParameters(self):
# self.params[3].enabled = False
self.params["p_name"].enabled = False
# execution script
import arcpy
def execute(parameter_dict):
arcpy.AddMessage(parameter_dict["p_name"])
if __name__ == "__main__":
parameters = {p.name: p.value for p in arcpy.GetParameterInfo()}
execute(parameters)
@JohannesLindner that's the kind of simple and innovative approach I was looking for! Honestly, I can't believe I haven't thought of that before. Bravo.
